During the first work session of the day I installed the B nuts and sleeves on the main fuel supply lines from the fuel tanks and flare the lines. Then I fabricated the fuel line from the electric fuel pump to the gascolator and finally I installed the oil temperature probe on the engine accessory case.
AN fittings installed on the fuel line running from the main fuel tank
Electric fuel pump to gascolator fuel line installed
